Graigslist seller: wrote:
1970 Road Runner Moonshine Running car - $37500 (St Louis Missouri)
Date: 2009-07-30, 7:14AM MDT
This is an amazing car!
Thats right this is a southern rust free car that was used for running moonshine, w/ only 35000 miles showing on the clock.
It started life as a St. Louis built car, w/ a 383 4 speed.
Although legend has it, that it was sent to Mr. Norms in Chicago, and fitted w/ a 440 6 pack engine, era correct.
The guy that repainted the car installed a Tremc 5 speed trany in it too.
The car has options like p/w, p/l, p/s, a Dana 60 w/ 331 posi gears; it has some really neat, after market back woods, mountain men options also.
For instance, open the glove box and you'll notice theirs no room for gloves because of the added options:
It has fog light switch, it has a jack switch, oil spray switch, that will spray 3-4 gals of oil (personally only used water) on to the road in about 10 seconds.
It also has a acc. switch, fuel pump shut off switch, and three other switches that turn off brake lights ,rear running lights, turn signals, and the dome light so they could switch drivers or just to get out in the dark.
The glove box also has fuel pressure gauge ,oil pressure gauge, and a vacuum operated trunk release.
Inside the trunk there's red lights that are low, a trunk lid mounted, lead end tire knocker, the oil tank, that sprays on to the highway by means on a copper tube and a home made manifold, which runs across the hot exhaust to cause a smoke screen and a oil slick, the battery, floor mounted tie downs.
It also has a power folding license plate, thanks to driver side power window cluster switches.
I could go on all day w/ what this car has, but for serious calls only and w/ money in hand, please call 314-517-5260.
May trade for 69 Z28 camaro or 69 RS/SS big block.
Moonshine Road Runner
- Erik Boattail
Found on St. Louis's Graigslist:
Starsky: I like your Lincoln. Huggy Bear: It's a '76. Won't be out 'til next year. But I know some people that know some people that robbed some people.....
Sie können auf meine Beiträge auf Deutsch antworten, danke
Das perfekte Fluchtfahrzeug :)
Aber, im Originalzustand wäre natürlich schöner :)
original waere er mir auch lieber, diese Gimmiks braucht kein Mensch
Gelten eigentlich 6 Kisten Moonshine im Kofferraum auch als Alkohol hinterm Lenkrad? :rolleyes:
![Bild](http://up.picr.de/27662096sb.jpg)
Mitglieder in diesem Forum: Bing [Bot] und 14 Gäste
